    enable
    configure terminal
  2. Enable X.509 V3 authentication:
    ssh x509v3-auth enable
  3. Configure X.509 V3 revocation:
    ssh x509v3-auth revocation-check-method {none | ocsp}
  4. Configure the X.509 V3 user name:
    ssh x509v3-auth username {overwrite | strip-domain | use-domain WORD<1-254>}
  5. Configure the X.509 V3 CA trustpoint name:
    ssh x509v3-auth ca-name WORD<1-45>
  6. Configure the X.509 V3 digital certificate subject name to use as the identity certificate:
    ssh x509v3-auth cert-subject-name WORD<1-45>
Display the certificate authority details:
Switch:1(config)#show certificate ca
CA table entry
CommonName                :   CaA2-1
KeyName                   :   pki
SubjectName               :   823
CaUrl                     :
UsePost                   :   0
SubjectCertValidityDays   :   0
Action                    :   (null)
LastActionStatus          :   (null)
LastActionFailureReason   :
CA-Auth Sha256Fingerprint :
UsedFor                   :   SSH-X509
CA table entry
CommonName                :   CaA1
KeyName                   :   rsa_2048
SubjectName               :
CaUrl                     :   http://192.51.100.9:8080/ejbca/publicweb/apply/scep/test/pkiclient.exe
UsePost                   :   1
SubjectCertValidityDays   :   365
Action                    :   (null)
CA-Auth Sha256Fingerprint :   bd9bb74b3f4d75e86113222a8d291b6349c7a42c457e487b9be0a48b4f09cc7c
UsedFor                   :
CA table entry
CommonName                :   CaA2
KeyName                   :   pki2
SubjectName               :   822
UsePost                   :   1
Action                    :   (null)
CA-Auth Sha256Fingerprint :   0ccb8d0c38d36cf427187f0e1dd380536c078fd6fae39ec9872187327912056b
UsedFor                   :   Default
The following table defines parameters for the ssh x509v3-auth command.
Variable Value
<none|oscp>
Specifies the X.509 V3 authentication revocation check method. The default is OCSP.
  • none - Specifies no revocation check method.
    oscp - Specifies Online Certificate Status Protocol (OSCP) as revocation check method.
overwrite|strip-domain|use-domain WORD<1-254>
Specifies the X.509 V3 user name configuration. The default is disabled.
  • overwrite - Specifies the switch to send the principal name and domain name from the certificate to the RADIUS server for authorization.
    strip-domain - Specifies the switch to send the principal name from the certificate without the domain name to the RADIUS server for authorization.
    use-domain WORD<1-254> - Specifies the switch to send the principal name from the certificate, with the domain name you entered to the RADIUS server for authorization.
ca-name WORD<1-45>
Specifies the X.509 V3 CA trustpoint name.
cert-subject-nameWORD<1-45>
Specifies the digital certificate subject name to be used as the identity certificate.
